Ambrane India, popular for its computer peripherals and mobile accessories has launched BT-6000 , its first Bluetooth speaker lamp that has unique touch controlled LED Light.
It is small enough to fit in your palms and lets you adjust brightness at the tap of the hand. It resonates through any solid surface and also offers hands-free calling capabilities when paired to a smartphone since it has a microphone.
Ambrane BT-6000 Bluetooth speaker lamp features and specifications
Uses Bluetooth 3.0 to connect to devices
A simple TAP to switch brightness on Top Mesh
3 brightness grades: Dim, Intermediate, High brightness
Microphone for calls, 3.5mm AUX input, Micro SD slot
Power Output: 3 Watt, Frequency Response: 20 Hz – 2.48 GHz
1200mAh battery with 6 hours of usage
Ambrane BT-6000 is priced at Rs. 1999, but it is available on Flipkart for as low as Rs. 1,399.
Commenting on the launch, Gaurav Dureja, Director Ambrane India says: We are thrilled to bring in a new category mapped to festive season. We have series of line ups awaiting in audio, each promising impeccable sound quality with no compromise on style. Like Ambrane has marked its no.1 position in Power Banks, we hope to recreate the history in the Audio category too.
BT 6000 is a unique product coz it syncs with Music beats at the tap of the hand, not only its an ideal gifting option for Diwali but surely a piece of conversation for every guest entering your house, with its stylish looks and one of its kind LED Disco Lights.
The BT6000 speaker has a range of 10m and a battery backup of 1200 mAH; that facilitates users to play music for as long 6 hours straight. The speaker also comes with an auxiliary port to let users connect other devices like an MP3 player and other audio sources via a 3.5mm audio port. Also bringing uninterrupted entertainment is the support to Micro SD and TF Card.
This festive season let the music play on Ambrane Speakers! The product is available with leading retail and etail stores across India.
Ambrane BT-6000 Bluetooth speaker with LED lamp launched for Rs. 1999
