AftabIN
- 28 Mar 2023
You can access hidden options and settings in jio fiber and airfiber stb and explore hidden possibilities from those options. With that we can apply custom dns server (can be used to block most of the ads in jio apps and other apps), create hotspot in your stb and use it in any other device. It will work in both wifi and lan mode. So it will benefit if your router is far in some circumstances. You can also check android version of your jio stb. Enable developer mode in fiber stb only. Access special permission apps, view any apps version and settings etc.
(Zoom video according to your need.)
