Few days after the listing appeared on the official site, YU has officially launched the YUNIQUE PLUS and YUREKA S smartphones. Both these have 4G LTE connectivity and run Android 5.1 (Lollipop) OS. The YUNIQUE PLUS has 2GB of RAM compared to 1GB of RAM on the YUNIQUE, while other specs are same.
YU YUNIQUE PLUS specifications
4.7-inch (1280 x 720 pixels) IPS Fully Laminated display with Corning Gorilla Glass 3 protection
1.2 GHz Quad-Core 64-bit Qualcomm Snapdragon 410 (MSM8916) processor with Adreno 306 GPU
2GB RAM, 8GB internal memory, expandable memory up to 32GB with microSD
Dual SIM
8MP rear camera with LED Flash, f/2.0 aperture
2MP front-facing camera, 83-degree wide-angle lens, f/2.4 aperture
Dimensions: 134.5×67.5×8.3mm; Weight: 128g
3.5mm audio jack, FM Radio
4G LTE, 3G HSPA+, Wi-Fi 802.11 b/g/n, Bluetooth 4.0, GPS
2000mAh battery
YU YUREKA S specifications
5.2-inch (1920 x 1080 pixels) display with Corning Gorilla Glass 3 protection
1.7GHz Octa-Core 64-bit Qualcomm Snapdragon 615 processor with Adreno 405 GPU
3GB RAM, 16GB internal memory, expandable memory with microSD
Hybrid Dual SIM
13MP rear camera with LED Flash, f/2.2 aperture, OmniVision OV13850 sensor, 1080p video recording
5MP front-facing camera, f/2.2 aperture, OmniVision OV5693 sensor, 84-degree wide-angle lens
4G LTE, Wi-Fi 802.11 b/g/n, Bluetooth 4.0, GPS
3000mAh battery
The YU YUNIQUE PLUS and YUREKA S are priced at Rs. 6999 and Rs. 12999, respectively and are available across retail stores pan India.
YU YUNIQUE Plus and YUREKA S officially launched for Rs. 6999 and Rs. 12999
Dual SIM
2000mAh battery
Hybrid Dual SIM
3000mAh battery
