write protection from your usb flash drive or memory card using the below method:
6 Mar 2011
1. Open Start Menu >> Run, type regedit and press Enter, this will open
the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If
the registry key StorageDevicePolicies does not exist, you will need to create it manually.
3. Double click the key WriteProtect in the right window and set the value to 0 in the Value Data Box and press OK button
4. Restart your computer and try copying files into your USB drives.
Popularity: 100%
