Chinese smartphone brand Vivo today launched its V3 and V3 Max smartphones for Rs 17, 980 and Rs 23,980 respectively. Both the smartphones run Android 5.1 Lollipop-based FunTouch OS and flaunts a fingerprint sensor.
The Vivo V3 comes with a 5-inch display while the V3 Max features a 5.5-inch Full HD display. On the hardware front, the V3 is powered on a Snapdragon 616 processor with 3GB RAM and 32GB internal memory which can be expanded up to 128GB via microSD card. It mounts a 13MP PDAF rear camera with dual LED Flash and an 8MP front facing camera. Powered by a 2,550mAh battery, connectivity features are 4G LTE, Bluetooth, Wi-Fi and GPS.
The bigger V3 Max is powered by a Qualcomm Snapdragon 652 processor with 4GB RAM and 32GB internal memory with support for up to 128GB. It has a 13MP rear camera with dual LED flash and an 8MP selfie camera. Other features are similar to the V3. It is powered by a 3,000mAh battery.
Vivo had recently launched its budget
Y31L smartphone for Rs 9,450. It features a 4.7-inch display and runs a 1.2GHz quad-core Qualcomm Snapdragon 410 processor coupled with 1GB of RAM. The onboard storage is 16GB which can be expanded further using a microSD card.
http://m.timesofindia.com/tech/mobi...d-V3-Max-smartphones/articleshow/51700485.cms
