Optimus_Prime
- 5 Oct 2015
as per the request from some of my brothers in this forum, I am creating this thread ...may be this is known by most of us, But I'd like to share with all so that it can help others in future.
first of all , We have to turn on HDMI-CEC(consumer Electronics Control) device control Option under Firetv settings. (find the attached screenshot)
now, do as per the following screenshot in your Bravia LED TV .
and make sure, device control keys option should be changed to NORMAL , follow the below screenshot
when we set above settings, we will get where We can see connected device(firetv stick)...please see the below screenshot
here I have connected Firetv stick in my HDMI 1 port which is also a MHL ( mobile high definition link) connection also ...in this page just press the activate button(which is washed out in white color) and then U can able to control your Bravia normal remote to nevigate firetv stick options.
and if you think what is Bravia Sync technology then BRAVIA Sync lets you link all compatible devices together for a simple one-push startup/shutdown process. Additionally, you can also operate these devices using just the BRAVIA remote control. With BRAVIA Sync, it’s all about convenience because entertainment should never be hard work!
Hopefully it will works for all...
and don't mind for low quality images ( its clicked from 2MP camera only)
cliked the like button if it helps
thanks folks'
thanks folks'
