UMi is all set to launch its UMi Fair budget smartphone on September 25th. It will be the most affordable smartphone with a fingerprint sensor, said the company. It already revealed the specifications of the UMi Fair that includes a 5-inch HD display, quad-core MediaTek MT6735 processor, Android Lollipop, 13-megapixel rear camera with dual LED flash and a 2-megapixel front-facing camera. It will come with metal body and has 4G LTE connectivity.
UMi Fair specifications
5-inch (1280 x 720 pixels) HD IPS display
1 GHz quad-core MediaTek MT6735 64-bit processor with Mali-T720 GPU
1GB RAM, 8GB internal memory, expandable memory with MicroSD
Android Lollipop
Dual SIM
13MP rear camera with dual LED Flash, Sony sensor
2MP front-facing camera
Fingerprint sensor
4G LTE / 3G HSPA+, WiFi 802.11 b/g/n, Bluetooth 4.0, GPS
2000Ah battery
The UMi Fair will be priced at just $99 (Rs. 6,510 approx.) and it will officially launch on September 25th, Friday.
www.fonearena.com/blog/157223/umi-f...-sensor-launching-on-september-25-for-99.html
