It was purchased in August 2019Look like panel/display/display cable issue bro, now a days most of branded tv facing this issues after 1 yearif it's under warranty contact cc, they will replace free of cost
Bro, tv fully not working or facing line onlyIt was purchased in August 2019
Any other solution?
Bro facing only line all other are working fineBro, tv fully not working or facing line only, if fully not working means visit nearby local & good service center, they repair panel,display @ good cost, if u contact Brand means they will ask 8k to 14k for display change
Don't waste money just ignore the lines, these lines will come in replaced display as well. Any power fluctuations happened these days?Bro facing only line all other are working fine
Then ignore bro, my suggestion once fully display gone, after only change displayBro facing only line all other are working fine
No any fluctuations broDon't waste money just ignore the lines, these lines will come in replaced display as well. Any power fluctuations happened these days?
