Sony Wireless Speaker SRS-XB402M
  • Views Views: Views 570
Bapun
3 Nov 2010
With powerful EXTRA BASS™ sound and Amazon Alexa built-in, the SRS-XB402M is the wireless party speaker that has all the answers. Dual passive radiators work together with two angled, full-range speaker units to enhance low-end tones, giving bass a boost. A wider frequency response and high sound pressure means more of the party can feel the beat. The speaker is waterproof and dustproof so you can listen in the kitchen or even the bathroom without concern. Additionally, the SRS-XB402M is shockproof and rustproof, so it’s durable enough to party anywhere. Party for as long as you want with up to 12 hours battery life*.
*When lighting is off in STANDARD sound mode and the volume is set to approximately half the maximum level. Actual performance may vary from the listed time due to the volume, songs played, surrounding temperature, and usage conditions.
