- 3 Nov 2010
- 8
Wireless Power Bank
Samsung Wireless Power Bank gives you the reliability and convenience to use wireless charging on the go. The new Wireless power bank is encased in strong, yet slim Aluminium body, designed to give you a truly portable, wireless experience.
The power bank comes with a large 10,000mAh capacity with options to charge two devices at once (1 wireless and 1 wired). It supports Adaptive Fast Charging and Quick Charge 2.0 in both wired and wireless charging.
The device is compatible with Samsung S series and Note devices (Galaxy S6 and above), Galaxy Buds, Galaxy Watch range and all Qi certified devices from other brands.
Wireless Charger Duo Pad
Wireless charger duo pad is designed to give a new meaning to wireless charging with Fast Charge 2.0. The latest Samsung Wireless charger charges your Galaxy S10 devices up to 30 minute faster compared to previous versions.
The Wireless Duo Pad lets you conveniently charge multiple devices with its dual charging pads. This is designed keeping the wearable ecosystem in mind where consumers can charge Galaxy S10 and Galaxy watch at the same time without the hassle of multiple chargers. The Wireless Charger Duo supports all Galaxy Watches along with Galaxy Buds, thus making it a go-to option for all your charging needs.
Wireless Charger Duo Pad is also compatible with Qi certified devices.
Price and Availability
The Wireless Power Bank is priced at INR 3,699 and available for purchase in two exciting colours- Silver and Pink. The Wireless Charger Duo Pad is priced at INR 5,999 and available in Black and White colours. Both these products will be available across all leading retail stores, Samsung e-Shop and Samsung Opera House. These products will soon be available on Amazon and Flipkart.
Specifications- Wireless Power Bank
Specifications – Wireless Charger Duo Pad
Samsung Introduces Wireless Power Bank and Wireless Charging Duo for the Truly Wireless Life
Colours | Silver and Pink |
Capacity | 10,000mAh |
Features | Wireless Charging output(FAST CHARGE, Qi, Galaxy Watch), Fast Wired Charging In&Out (AFC, QC2.0 max.15W) |
Material | Aluminum, PC |
Dimension | 149.93 x 70.8 x 15.09 mm |
Weight | 234g |
Colours | Black and White |
Features | Simultaneous dual wireless charging, FAST CHARGE 2.0, FAST CHARGE 1.0, Qi, Smart Watch Charging |
Interface | USB Type-C |
Dimension (WxHxD) | 195 x 18.05 x 92 mm |
Weight | 168 g |
