Meizu M3 Max With 6-Inch Display, 4100mAh Battery Launched...
Following the launch of the Meizu M3E last month, Chinese smartphone company Meizu has launched the M3 Max in its home country. It has been priced at CNY 1,699 and goes up for pre-orders from September 12. The M3 Max will be available in Champagne Gold, Grey, Rose Gold, and Silver colour variants.
Like the M3E before it, the Meizu M3 Max is a hybrid dual-SIM (Nano-SIM) smartphone that runs on a MediaTek Helio P10 processor, with four Cortex-A53 cores clocked at 1GHz and four Cortex-A53 cores clocked at 1.8GHz, alongside 3GB of RAM.
The Meizu M3 Max's highlight is its 6-inch full-HD (1080x1920 pixel) touchscreen. It sports a 13-megapixel rear camera and a 5-megapixel front-facing shooter. The phone packs 64GB of inbuilt storage that can be expanded via microSD card 9 (up to 128GB).
The smartphone supports such connectivity options such as Wi-Fi, GPS, Bluetooth, 3G, 4G. Sensors on the phone include proximity sensor, ambient light sensor, accelerometer, and gyroscope.
Notably, the M3 is powered by a 4100mAh non removable battery, measures 163.40x81.60x7.7 and weighs in at 189 grams.
Apart from the Meizu M3E, the Chinese mobile firm also launched two budget smartphones last month - the Meizu U10 and the Meizu U20. Before that, it launched its Mix swartwatch with an analogue display.
Meizu M3 Max With 6-Inch Display, 4100mAh Battery Launched | NDTV Gadgets360.com
