Logitech K375s Multi-Device Wireless Keyboard and Stand Combo Launched at Rs. 1,995
  • Views Views: Views 562
Logitech has launched its K375s multi-device wireless keyboard and stand combo in India, which will be made available for purchase from Logitech.com from Monday, December 26. As the name implies, the full-sized keyboard allows users to switch between multiple devices - up to three paired devices at a time - whenever required.
The company says that as the keyboard can pair with several devices, it will help users stay connected across their preferred devices and platforms. "The K375s Multi-Device lets you easily switch between devices with the push of a button. You can start typing on your computer and finish an email message on your tablet or create a text on your phone with just one key. The full-size layout and special function keys provide a quiet and comfortable typing experience in a spill-resistant design,"
Logitech said.
Apart from providing the option to switch between devices, the the Logitech K375s keyboard comes with a universal stand that helps users to keep their mobile device at the right typing angle and hence makes the typing faster, smoother, and more convenient, said Logitech's Cluster Category India Head Ashok Jangra.
"The separate universal stand has a soft rubber base and a carefully designed cradle that holds mobile devices at the ideal angle to read or type. And, the keyboard is OS-adaptive, so whether you're using Windows PC, Android or iPhone, the keyboard layout is familiar," the company said in a statement announcing the Logitech K375s's India launch.
The keyboard comes with a non-rechargeable battery that lasts up to two years, as per company's claims. The Logitech K375s multi-device wireless keyboard has a wireless range of 33 feet. There is a wireless encryption between the keyboard and the computer and users can either use the company's Unifying USB receiver or Bluetooth Smart tech to pair the devices.
Logitech K375s Multi-Device Wireless Keyboard and Stand Combo Launched at Rs. 1,995 | NDTV Gadgets360.com
