LG has launched its second-generation curved display smartphone in India, the G Flex2, priced at Rs. 55,000. The smartphone will be available from this month in Platinum Silver and Flamenco Red colours.
The LG G Flex2 when announced back in January at CES 2015 was the first smartphone to run Qualcomm Snapdragon 810 (a 64-bit octa-core SoC). It is coupled with the Adreno 430 GPU and 2GB of LPDDR4 RAM. The single-SIM smartphone runs Android 5.0 Lollipop and features a 5.5-inch full-HD curved P-OLED display with a 1080x1920 pixels resolution and a 403ppi pixel density.
The LG G Flex2's display has a 700mm-radius curvature, while the back is slightly sharper with a 650mm-radius curvature for grip. LG says the Corning Gorilla Glass 3 has been toughened approximately 20 percent from the previous generation with the firm's own special chemical treatment technology - LG calls this Dura-Guard glass. The whole phone is supposedly 30 percent more durable than the original.
The LG G Flex2 sports a rear 13.0-megapixel camera with optical image stabilisation (OIS+), dual-LED two-tone flash, and laser-guided autofocus just like the LG G3. It sports a 2.1-megapixel front-facing camera. The G Flex2 will come in 16GB and 32GB storage variants that are expandable via microSD card.
(Also see: LG G Flex2 vs Samsung Galaxy S6 Edge)
Connectivity options on the LG G Flex2 include 4G LTE-A with tri-band carrier aggregation, HSPA+, Wi-Fi 802.11 a/b/g/n/ac, Bluetooth Smart Ready (Apt-X) 4.1, NFC, SlimPort, GPS/ A-GPS, GLONASS, and USB 2.0. The device measures in at 149.1x75.3x7.1 - 9.4mm, and weighs 152 grams. The curved handset packs a curved embedded 3000mAh non-removable battery.
The other features include things like a simple hand 'Gesture Shot' recognisable from up to 1.5 metres away; 'Gesture View' to check last clicked shot; 'Glance View' to swipe down for notifications even when the screen is off, and 'Fast Charging' - which can charge the battery up to 50 percent in under 40 minutes.
LG G Flex2
Key SpecsNews
Display5.50-inchProcessor2GHzFront Camera2.1-megapixelResolution1080x1920 pixelsRAM2GBOSAndroid 5.0Storage16GBRear Camera13-megapixelBattery capacity3000mAh
http://m.gadgets.ndtv.com/mobiles/news/lg-g-flex2-with-55-inch-curved-display-launched-at-rs-55000-671816
