LAUNCH: Sharp's king size 3D Internet LED will cost Rs 19 lakh
  • Views Views: Views 689
What's new: The 90-inch size is definitely new. It is even more unique that this form factor has come in a Internet television.
What else is there: The television has to be FullHD as otherwise all you will get to see is giant size pixels. However, it is surprising that at this size and price the company has not made if Ultra HD or 4K resolution. The panel is capable of running at 200Hz, promising detailed and clear action. The Smart TV functionality means full access to Aquos Net+ portal, including apps such as Skype and web browsing. It can be controlled using Sharp's own application, which allows you to easily use or browse the internet on the TV, as well as a standard remote control. Made of aluminium, the set weighs 64 Kg.
Price: Rs 19,99,990
LAUNCH: Sharp's king size 3D Internet LED will cost Rs 19 lakh - Indian Express
