Kingston has launched MobileLite Wireless G3 and MobileLite Wireless Pro, two new additions to its Wireless family. Both these have USB ports and SD card slots so that you can access data from them wirelessly over Wi-Fi (dual-band 802.11ac) using the MobileLite app for Android and iOS.
The Kingston MobileLite Wireless G3 packs a 5400mAh battery that offers up to 11 hours of continuous use and the MobileLite Wireless Pro offers battery life of up to 12 hours with the built-in Li-ion 6,700 mAh battery. The MobileLite Wireless Pro also packs 64GB of storage.
Kingston MobileLite Wireless G3 and Wireless Pro specifications
Inputs for Storage USB and SD – reads SD, SDHC, SDXC andmicroSD/microSDHC/microSDXC (with included adapter)
MobileLite Wireless Pro only — 64GB Storage Included
Supported File Systems FAT, FAT32, NTFS, exFAT
Dimensions 115mm x 80mm x 24mm; Weight MLWG3: 192g, MLW Pro: 194g
Wireless Network Interface 2.4GHz 802.11b/g/n & 5GHz 802.11ac
WLAN Ethernet Port to function as an access point
Rechargeable Battery: MLWG3: 5,400mAh with up to 11 hours of continuous use; MLW Pro: 6,700mAh with up to 12 hours of continuous use
Local Storage – wirelessly transfer files to and from the MobileLite app and the MobileLite Wireless hardware
Camera Roll support: allows users to move photos and videos from their mobile device to MobileLite Wireless to free up space
Cable USB to micro USB cable included
Customisable device name (SSID) User selectable Wi-Fi priority list when there are multiple APN/Key available
The Kingston MobileLite Wireless G3 is priced at Rs. 4999 (MRP) and the MobileLite Wireless Pro is priced at Rs. 8,999 (MRP). Both are available through online and retail storage and are backed by a two-year warranty.
Commenting on the launch, Nathan Su, Flash Memory Sales Director, APAC Region, Kingston, said: MobileLite Wireless G3 and Pro are great for iOS and Android mobile device users on the go.We’ve increased the battery capacity for charging and introduced a new Pro version with on-board memory for even more convenient access to extra storage. Users no longer have to worry about having enough battery life or storage on their smartphones and tablets.
Kingston MobileLite Wireless G3 and Wireless Pro with built-in battery launched in India
