Karbonn Platinum P9 with 6-inch display, 8MP front camera now available for Rs. 8899
  • Views Views: Views 403
Thakur
Banned
30 Aug 2013
Karbonn Platinum P9 , the company’s first smartphone in
the Platinum series is available from online retailer
Snapdeal .
It has a 6-inch qHD display, is powered by a 1.3GHz quad-core processor and runs on Android 4.4 (KitKat).
It has a 8-megapixel rear camera with LED flash and a 8-megapixel front-facing camera.
It comes with dual SIM support and 3G connectivity, similar to most other Karbonn smartphones.
Karbonn Platinum P9 specifications 6-inch qHD (960 × 540 pixels) IPS laminated display with Corning Gorilla Glass 3 protection 1.3 GHz quad-core processor
1GB RAM, 16GB internal memory, Expandable memory up
to 32GB with micro SD
8MP Auto Focus Camera with LED flash
8MP front-facing camera
Dual SIM
3.5mm audio jack, FM Radio
3G, Wi-Fi 802.11 b/g/n, Bluetooth with A2DP and GPS
2500 mAh battery
The Karbonn Platinum P9 comes in Black color and is priced
at Rs. 8,899.
http://www.fonearena.com/blog/134135/karbonn-platinum-p9-with-6-inch-display-8mp-front-camera-now-available-for-rs-8899.html
