Karbonn on Wednesday launched a range of new smartphones and feature phones in the market as a part of its festive offer. The company has introduced four new smartphones namely Karbonn Alfa 112, Alfa A91 Power, Alfa A93 Pop, and Titanium S205 Plus alongside two feature handsets - K18 Jumbo and M105.
The Android-based Karbonn Alfa 112, Alfa A91 Power, Alfa A93 Pop and Titanium S205 Plus are priced at Rs. 2,890, Rs 3,290, Rs. 3,490 and Rs. 6,790, respectively. The K18 Jumbo and M105 cost Rs. 990 and Rs. 940 respectively. The company said it would also be offering special festive season discounts of up to 50 percent on Titanium Mach Five, Titanium Mach Two and Titanium S201 via e-commerce websites.
The dual-SIM (WCDMA+GSM) supporting Karbonn Titanium S205 Plus (seen above) runs Android 5.1 Lollipop out-of-the-box and features a 5-inch HD (720x1280 pixels) resolution IPS display with Dragon Trail Glass protection. It is powered by an unspecified dual-core SoC clocked at 1.2GHz and clubbed with 2GB RAM. It also houses 16GB of inbuilt storage, which can be further expanded via MicroSD card (up to 32GB). In the camera section, the Titanium S205 Plus sports an 8-megapixel autofocus rear camera with dual LED flash and a 3.2-megapixel front-facing camera as well. The smartphone supports 3G, Wi-Fi 802.11 b/g/n, Bluetooth, GPS and Micro-USB connectivity features alongside proximity sensor, G-Sensor and comes backed by a 2200mAh Li-Po battery.
The Android 5.1 Lollipop-based dual-SIM (WCDMA+GSM) Karbonn Alfa A93 Pop (seen above) features a 4.5-inch FWVGA (480x854 pixels) resolution display; 512MB RAM; 8GB inbuilt storage, which can be further expanded via MicroSD card (up to 32GB); a 2-megapixel rear camera; a 0.3-megapixel front-facing camera, and a 1400mAh battery. Connectivity features and processor remains the same as Titanium S205 Plus.
The dual-SIM (WCDMA +GSM)
Karbonn Alfa A91 Power (seen above) runs the older Android 4.4 KitKat out-of-the-box and features a 4-inch WVGA (800x480 pixels) resolution display; unspecified 1GHz processor; 256MB RAM; 512MB inbuilt storage, expandable via microSD card (up to 32GB), and Li-ion 2000mAh battery. The connectivity options and camera setup stay the same as Karbonn Alfa A93 Pop mentioned above.
The Android 4.2 Jelly Bean-running dual-SIM (GSM+GSM) Karbonn Alfa 112 (seen above) features almost the same specifications as the aforementioned Karbonn Alfa A91 Power but misses out on 3G connectivity and is backed by a Li-ion 1300mAh battery.
The dual-SIM (GSM+GSM) Karbonn K18 Jumbo feature phone sports a 2.4-inch LCD display, VGA (0.3-megapixel) rear camera, FM radio, GPRS, Bluetooth and is backed by a 1800mAh battery. The dual-SIM
Karbonn K-Touch M105 sports a smaller 1.8-inch LCD display, digital rear camera and 800mAh battery with rest of the specifications same as the K18 Jumbo.
m.gadgets.ndtv.com/mobiles/news/ka...93-pop-and-titanium-s205-plus-launched-757837
