Intex has launched Intex Aqua Power HD 4G, the company’s latest smartphone in the Aqua series, which is the successor of the Intex Aqua Power HD that was launched last year. It packs a 5-inch HD screen, is powered by the same 1.4 GHz octa-core MediaTek MT6592M processor, runs on Android 5.1 (Lollipop) and comes with a 3900mAh battery. It has a 8-megapixel rear camera with LED flash and a 5-megapixel front-facing camera.
The back cover has a textured painting finish. It has dual SIM support and 4G connectivity.
Intex Aqua Power HD 4G specifications
5-inch (1280 x 720 pixels) HD IPS display
2GB RAM, 16GB internal memory, expandable memory up to 32GB with MicroSD
Dual SIM
8MP rear camera with LED Flash
5MP front-facing camera
3.5mm audio jack, FM Radio
Dimensions: 144×72.8×9.6mm; Weight: 155g
4G LTE/3G HSPA+, WiFi 802.11 b/g/n, Bluetooth 4.0, GPS
3900mAh battery
The Intex Aqua Power HD 4G comes in Champagne, Blue and Grey colors and is priced at Rs. 8,363.
Commenting on the launch, Keshav Bansal, Director, Intex Technologies, said: With the launch of new Aqua Power HD 4G, we are looking at offering a unified and connected smartphone experience, which makes consumers’ lives simpler and at the same time more amazing with benefits that come with the smartphone.
Intex Aqua Power HD 4G with 5-inch HD display, 3900mAh battery launched for Rs. 8363
Dual SIM
3900mAh battery
