How To Connect DVD To LED Monitor?
  • Thread starter Thread starter AsitPaul
  • Replies Replies: Replies 5
  • Views Views: Views 1,233
AsitPaul
7 Oct 2011
My Videocon d2h SatDVD 5002 supports 5.1 Channel Audio OutPut, S/PDIF, S-Video, Component (YPbPr) as well as Composite (AV) output.
Can I Connect this SetTopBox directly with LED Monitor without using Computer?
In short, is there any LED Monitor (24 inch etc) available in India with YPbPr or AV Input etc?
Want to buy LED Monitor just to use as Television, since monitors are really cheap than LED/LCD TV.
You can use external TV tuner, that can connect to the monitor without full pic installation and connect audio out put to speaker.
Thanks a lot Admn,
But what price?
If Monitor + Tuner price is greater than standalone LED TV, then no use!
No you can find good external tv tuners from 700-1000 rs. ;)
Asitpaul bro you can use a Component to DVI converter cable to watch programmes on your LCD monitor as every DVD player has Component out ,S video out etc. Good quality DVD are now available with HDMI/DVI out etc.
You can use this component easily available on Computer/Electronics shops:
COMPONENT TO DVI CONVERTER:
source online to buy: DVI to Component Adapter | eBay
