help+HELP+help
  • Thread starter Thread starter saumya
  • Replies Replies: Replies 12
  • Views Views: Views 1,107
saumya
28 Jan 2015
I want to know how can I play video/ mp3 / picture play directly my smartfone to normal tv it is possible......
If you have a TV with HDMI port, you can get a Chromecast which does exactly this.
Buy windows 10 smartphone, it has continuum
saumya said:
bro I say about normal TV its only av/ normal audio video port....
If it's normal TV, I don't think it's feasible. But I'll let others comment.
if you have Nokia 5800 Xpress Music then it can play in Normal TV. And about other phones i don't know how to play content in Normal Tv
It's possible for normal Tv also with the help of Continuum of Windows 10 , check this video
Checked and read more about it. Lot of factors involved in this. TV should have HDMI/USB I think. But good try by Microsoft.
http://m.windowscentral.com/how-continuum-windows-10-mobile-works-lumia-950
saumya said:
If it's only audio, that cable might work. If you need video then It's not straight forward. You would need converters which will cost you a lot. Look at the below link.
http://androidforums.com/threads/android-to-rca-connections.733509/
