Max redefines audio, in a way that only Google can—with AI. Its high-fidelity sound is built on a foundation of premium hardware. With dual 4.5-inch high-excursion woofers, you’ll get deep, balanced bass. And Max can play loud, really loud…so you can fill even the largest room in your home with your favorite music. In fact, it’s 20 times more powerful than the original Google Home.
Max is our first speaker with Smart Sound, a new audio experience powered by Google’s artificial intelligence. It’s what allows Max to adapt to you—your environment, your context, and your preferences. Smart Sound automatically adjusts for where you place Max in a room, so if you decide to move your speaker a few feet, it will dynamically tune itself within seconds.
Max works with a wide range of music services and supports Bluetooth and auxiliary port . And Max was made to fit your space and style; it can be placed vertically or horizontally and comes in two colors—Chalk and Charcoal.
