Do usb2.0 devices supported with usb3.0 port?
  • Thread starter Thread starter piinku1
  • Replies Replies: Replies 7
  • Views Views: Views 1,898
Your Query is confusing pinku bro ? But I will try to rectify the problem ;)
If your question is USB-3 is compatible with USB-2 then Answer is yes and if you want that USB-3 Devices can be play with USB-2 then Answer is NO as we can't play a DVD in VCD player . But you can play any USB-2 Device in USB-3 without any hesitation.:tup
If your question is USB-3 is compatible with USB-2 then Answer is yes and if you want that USB-3 Devices can be play with USB-2 then Answer is NO as we can't play a DVD in VCD . But you can play any USB-2 Device in USB-3 without any hesitation.:tup
i knew it.
but pratically i am even unable to plug-in usb-2 devices to usb-3 ports.
piinku1 said:
i knew it.
If you knew its good ,Now you mean The USB-2 devices are not plugging in usb-3 ,then you have to get usb-3 to usb-2 connector from PC hardware shop.The pin connection miss match + size of port may not be compatible ok.
bro USB 3.0 is backward compatible, means you can use a USB 2.0 device on USB 3.0 port but with only usb 2.0 speed.... usb3 has 5 extra pins than the usb2 connectors but doesnt mean you cannot connect a usb2 device to a usb3 port.... :tup:tup:tup
i am really surprised to hear that you cannot plug-in usb-2 devices to usb-3 ports... :shy:shy:shy
yes,it is true.My younger brother has bought a new hp pavilion laptop which has 2 usb3.0 ports.Both of us are unable to plug-in pendrive,data card into it.:-/
