CoviSelf - India’s first self testing kit for Covid
  • Thread starter Thread starter iDJ
  • Replies Replies: Replies 11
  • Views Views: Views 5,017
Bad idea. Really a bad idea.
It's not if they have a plan to track the people who tested positive. Like they can make sure adding a mobile number and aadhar card is mandatory to access the test results.
Results generating only once you scan the test kit and code. I'm sure mylab will report any positive results to authority.
This is good kit, will come handy and avoid going to hospital specially if you at home isolation and feels better after sometime.
Exactly assuming the kits give genuine results it will reduce the time needed for results to come and decrease load on the Labs.Moreover,in future it will come handy if you want to have some gathering and all.
Thank god You explained the logic in correct way otherwise i was panic to see some reply which says that it is not good idea.
