Asus Zenfone Max Pro M1
  • Replies Replies: Replies 123
  • Views Views: Views 17,026
Bapun
3 Nov 2010
Asus Zenfone Max Pro Intrigue Store Online - Buy Asus Zenfone Max Pro Intrigue Online at Best Price in India | Flipkart.com
Zenfone Max Pro M1 will have a 5,000 mAh battery, "pure" Android Oreo
The phone will live up to its name with a 5,000 mAh battery, which should last a long, long time with the 14nm Snapdragon 636 chipset.
The phone will feature a 6” screen with an 18:9 aspect ratio and will run “pure Android Oreo”, though we’re not 100% sure if this means Android One or not. The memory will feature up to 6 GB of RAM and up to 64 GB storage (suggesting a 4 GB / 32 GB version). The good news is that there will be three card slots – two for SIMs and one for a microSD.
The Zenfone Max Pro M1 will sport a dual 16 MP camera on the back and a 16 MP selfie camera with face unlock. Next to the rear camera there will be a fingerprint reader (which fires in 0.3 seconds).
If it's priced around 15k then it will make note5 pro available to all ;).
Specs are almost same as note 5 pro
But Dedicated micro sd card slot ,5000mAh battery and Oreo out of the box with stock android makes it different
If they provide fast charge and usb type c then it will be icing on cake
