Airtel fiber speed 2 MBPS in evening after 6 PM
  • Thread starter Thread starter Sakthi1982
  • Replies Replies: Replies 1
  • Views Views: Views 203
Sakthi1982
7 Nov 2024
In the daytime, the download speed is near about 40 MBPS, and in the evening it is reduced to 2 MBPS.
Some times after rebboting the router it is working at 40 MBPS.
Still issues remains same,no technical support is there to solve it.
Please suggets.
If you are downloading more things in GB in single day, this may be an cause 2 mbps drop. If you put out fiber and reinsert into airtel fiber router. you will get mbps as per plan. it's not an issue but stop over doing higher gb downloading with your unlimited plan also having some conditions. i will suggest you to do it at the end of 3-4 days of every month.
