Discussion 5.1 output from MI Box
  • Thread starter Mr.Bhat
  • Start date
  • Replies: Replies 12
  • Views: Views 1,369
Mr.Bhat
30 Apr 2011
Can we get 5:1 audio from audio port of Mi Box 4K...Is there any converters...If so is that 5:1 is same like original...
Ok, Optical out supports Dolby Digital i.e. up to 5.1 channels. If your home theater has an optical IN, you can directly connect from mi box optical OUT to that. If your home theater is having analog input (6 different inputs for each channel), you would then need a converter as below.
Tobo 5.1 Channel HD Audio Rush,Digital Sound Decoder Converter,Optical SPDIF Coaxial Dolby AC3 DTS Stereo(R/L) to 5.1CH Analog Audio Black Amazon.in: Buy Tobo 5.1 Channel HD Audio Rush, Digital Sound Decoder Converter, Optical SPDIF Coaxial Dolby AC3 DTS Stereo(R/L) to 5.1CH Analog Audio Black Online at Low Prices in India | Tobo Reviews & Ratings
Sorry .Yes was posted mistakenly..
I have edited that post...
Is the converted Dolby audio has the same quality of Original Dolby 5:1 sounds?
