Pan India Telecom Spectrum holding chart 2025
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,772 comments
Share article:
Follow us
Pan-India-Telecom-Spectrum-Portfolio-2025
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Spectrum sharing is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of an operator acquiring the spectrum.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of an operator acquiring the spectrum.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1524)Forum replies (248)
Loading new replies...
Reply 4 likes
Reply 3 likes
1,772 thoughts on “Pan India Telecom Spectrum holding chart 2025”
  1. Did BSNL officially get 5 MHz B1 in Mumbai circle ?? If so, why not in Delhi circle, and why only 5 MHz instead of 10.
    Did BSNL also get 700 MHz officially in both MTNL circles? Have they started deploying it ?
    I don’t understand why gov is not giving n78 in these 2 circles if Vi plans to use it
    Reply
Leave a Comment
