Seeking Help Suggestions required for AC
  • Thread starter hike
  • Start date
  • Replies: Replies 1
  • Views: Views 788
hike
1 Aug 2014
So guys I'm from Jaipur, Rajasthan
My room is 15 feet × 15 feet
It's on ground floor and direct sunlight ☀️ stay from 10 to late evening. Could you please suggest me AC which should I bought?
1 Ton is enough?
I've searched few of them but confused and you are my always solution.
Considering your room size, i would suggest you with a 1.5T. Don't go for 5star rated models, it's just a gimmick to fool us. The power consumption is not astronomically low for 5star. But it's super expensive. So better to go for 3star, which somewhat reduces power consumption and at the same time lot cheaper than 5star rated. Go with copper models instead of aluminium. They provide better cooling as well as durability. Inverter models are bit expensive but they provide faster cooling and also reduce power consumption.
I am not going to influence you with a particular brand or model, i will leave that to your liking. Just choose based on the points explained above.
