Hi kindly suggest me Mobile handset below 15k with good physical strength , I mean in case it falls its touch screen should not stop working or there is least damage. As father is going to use mobile so it should be free of adds, if its stock android then it would be better .dual sim with dedicated memory slot, good battery/fast charging etc etc are minimum requirements. Also minimum memory be 4/64 GB
Also it would be better if bought offline
If not then is it possbile for 1 day shipping in amazon/flipkart???
How is realme as a phone does it have probelms of adds
