Seeking Help Need suggestions for 32 GB Pen drive
Ashok L
15 Oct 2013
I need small suggestion in buying 32 GB pendrive. Which brand should I prefer...???
Main use for me is to connect with Airtel HD+ box for recording
Go For Sandisk Bro I am Using Sandisk 32 GB OTG MRP. 500/-00
I used Sandisk only bro previously. Both box and pendrive got faulty because of that. Noe that pendrive only working in PC and not on Airtel boxes. So I just need some other brand as I don't want to spoil my new HEVC box again
Go for HP Or Toshiba Or sttantorium. All Brand have Good quality.
Brand doesn't matter much. Some manufacturer gives limited lifetime warranty and some gives 5 or 2 year warranty. Check before buying. Also, make sure you buy USB 3.0 pendrive. USB 2.0 pendrives are slow where, 3.0 pendrive are much faster even if you connect in USB 2.0 slot. If your house doesn't have ground connection (earthing) then avoid buying metal pendrives. It can give you electric shock.
