Need help : Planning to buy Vu 50" UHD Tv
sankar17
3 Feb 2012
I am planning to buy Vu 50" UHD Tv. Any one is using Vu TVs.
If so please share your comments. It will help me.
I bought a 40 inch vutv in big billion sale few months back...very good PQ with HD stb . value for money considering I got it for 20k....but now they have brought new line of smart TV's with internet capability and Digital audio output....try to get one of them...
Thanks guys. I read in one of the reviews "only Tatasky HD channels will be good and SD channels are not good" is it true?
Also heard the remote is not good and can't use it with Tatasky universal remote
I have vu 32 inch full HD TV. My TV had yellowish in corner and they replaced after one month terrible follow up's. But new TV is very good. Sd channel picture quality is good on sun direct also. Note service depends on location I think. Menus is poorly designed in 32 inches. It plays almost all formats except some mkv format sound won't come.
Bro please check, does this tv support vp9 codec for 4k. if not then wait or buy another tv with vp9 codec.
Is VU customer services available for metro cities only ??
Do you recommend to buy it for ppl staying away from metros , like is small towns ...
I need help regarding service ...
Else Suggest any other brand which has good service centres .. my budget around 15k for 32 inch TV ...
