Motorola's Android beginning on T-Mobile goes way back to the CLIQ which was launched well over a year ago and was consequently followed with the CLIQ XT last spring – with the CHARM being the most recent addition. In all honesty, those devices lacked the charisma and appeal characteristic to Verizon's line of DROID models. Now that we're heading into the busy fall season, Motorola is looking to grace T-Mobile's lineup with a handset that will encompass a special niche market to strikingly separate it from anything else previously seen. Even though it might pack some features that might appear as novel to some people, the Motorola DEFY MB525 has some interesting items hidden in tow that just might enable it to defy the odds.
Design:
Positioned to be a rugged type of handset, it's actually the second Android to follow after the Motorola i1 for Sprint and Boost Mobile. However, it decides to follow a completely alternate path for its construction, as its exterior is mostly defined to resist water as opposed to drops. The two-tone hard plastic shell feels durable enough, but we'd suspect that it would still blemish under the most extreme conditions if it were dropped onto the hard pavement. Instead, it seems more capable of tackling water head on since the soft touch feel gives way to the illusion of it donning some kind of neoprene suit. In fact, it aids it in repelling dirt and smudges which ultimately keeps it looking clean all the time. The minimalistic design might make it seem quaint at first, but the screws outlining the sides of the handset will make you think otherwise. Additionally, it feels rather normal sized (0.53” thick) and in weight (4.16 oz) to make it feel well constructed all around. It sure ain't all that pretty, but when you're trying to beat the elements, it's more than justifiable.
Design:
