• Welcome to OnlyTech Forums
    Log in or Register
LAVA Pocket Wireless Router W150 Comes With Impressive Specs
8 Jun 2011
Lava Mobiles, one of the popular desi handset companies is keen to provide better value for money with their products.
Now Lava breaks into pocket wireless router market with their flagship product – W150 which comes with power packed specs and excellent value for money.
Lava W150 is priced most attractively at Rs2900 (MRP).
Lava W150 boosts of many unique impressive features targeted toward all customer profiles from home individuals to SME to business houses.
Technical Specifications of LAVA W150:
Share internet & data between maximum 32 users within 50 meter range.
Seamless connection to Internet through ADSL/Cable Broadband (RJ45) port or USB Data card – both EVDO & 3G dongles supported.
Plug & Play, No software installation required – Windows XP/Vista/7, Android 1.6+, Mac OS 10.4.9+ supported
Fast transfer of data at a speed of upto 150 Mbps with Wi-Fi standard IEEE 802.11 b/g/n (2.4 GHz band)(802.11n:150Mbps / 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps / 802.11b: 1, 2, 5.5, 11Mbps ). Compliance to 802.11b/g/n standard with 100mV transmission power.
Convert your home / office into Wi-Fi zone with Signal coverage of up to 50 meters. Create wifi hotspot anytime anywhere.
Sufficient Battery for up to 4 hour’s standalone use with powerful rechargeable 2300mAH Li-Ion Battery.
Portable Sleek, Stylish router comes with 94*61*14.7 mm dimension and 100g weight.
Simple handling and management over web interface. All most all gateways are supported (TCP/IP, UDP, DHCP Server, NAT/NAPT, DNS Relay, SNTP, UPnP, Static Routing, MAC/URL/IP filter, VPN Pass-through). MAC Clone & Radius Server.
Secure your network with passwords and built in firewall (WEP Encryption, 64/128 bits, WPA, WPA2; Authentication: 802.1x, Pre-Shared Key (PSK); Encryption: AES, TKIP; Single SSID Broadcast; SSID –Supported)
LED Indicator x 5(Power, Battery, WIFI, Signal, Network Mode)
Ports – Standard USB 2.0 Modem Interface, DC Power Input 5V 1.5A (12V CAR USE), 10/100 Ethernet x 1- RJ45, microUSB for charging.
