iSK
- 16 Jul 2013
Lava has launched Iris X1 Atom S , the latest
smartphone in the Iris X1 series. This budget
smartphone has a 4-inch WVGA screen, is
powered by a 1GHz processor and runs on
Android 4.4 (KitKat). It has a 5-megapixel rear
camera with LED flash and a VGA front-facing
camera. It has similar design as other Iris X1
series smartphones, comes with dual SIM
support and 3G connectivity.
The Lava Iris X1 Atom that was launched
recently has a better processor and a bigger
battery compared to the Iris X1 Atom S.
Lava Iris X1 Atom S specifications :-
4-inch (800 × 480 pixels) touch screen display
1 GHz processor
512MB RAM, 8GB internal memory,
expandable memory up to 32GB with micro SD
Dual SIM
5MP rear camera with LED flash 0.3MP (VGA) front-facing camera
3.5mm audio jack, FM Radio
Dimensions: 125.5mm X 63.4mm X 9.65mm; Weight:
3G, Wi-Fi 802.11 b/g/n, Bluetooth and GPS
1400 mAh battery
Link
