Sivabhaskar
- 23 Feb 2018
- 2
This is a Jio STB question, which is similar to a question (linked below) I posted on the Sun Direct forum yesterday.
Jio STB has the option to choose between the following FULL HD resolutions:
1080i 50Hz
1080p 50Hz
My TV can play both the above resolution types.
In the Sun Direct thread, I was basically suggested to leave the default setting as it was (the Sun Direct STB's default setting is AUTO, which displays in 1080i).
The reason given was, no TV Channels currently broadcast their programs in 1080p. All TV channels seem to be broadcasting only in 1080i. That is why all DTH providers are in turn providing us all content in 1080i (and not in 1080p).
Because Sun Direct's default setting was 1080i, I left it as it was (AUTO).
However, the Jio STB seems to be defaulting its setting to 1080p 50Hz.
So now I am confused. Should I leave it as 1080p 50Hz, or should I change it to 1080i 50Hz?
Jio STB Users:
1) Does the Jio STB default to 1080p for you too?
2) What setting would you suggest? 1080p or 1080i?
Any help is appreciated
Note:
This setting could be found under:
Settings --> HDMI Resolution
My Sun Direct Question:
Seeking Help - Sun Direct HD: 1080p or 1080i ?
1080i 50Hz
1080p 50Hz
Jio STB Users:
Note:
