G Guri Member Joined 17 Jan 2019 Messages 122 Reaction score 42 11 Sep 2019 #1 Hi I notice from today that jio had stop incoming/outgoing on all telecom even on jio numbers on same day your plan expired. Anybody else facing same
iDJ Elite Contributor Joined 23 Aug 2018 Messages 24,590 Solutions 5 Reaction score 30,406 11 Sep 2019 #2 Guri said: Hi I notice from today that jio had stop incoming/outgoing on all telecom even on jio numbers on same day your plan expired. Anybody else facing same Click to expand... No. Still using a number last recharged on January. Also using ₹251 plan which is just data only plan. Recieving incoming calls on both numbers.
Akash Solanki Member Joined 13 Jan 2019 Messages 171 Reaction score 396 11 Sep 2019 #3 Guri said: Hi I notice from today that jio had stop incoming/outgoing on all telecom even on jio numbers on same day your plan expired. Anybody else facing same Click to expand... Here working fine
T thisisjagan Member Joined 28 Jun 2016 Messages 1,545 Reaction score 1,797 11 Sep 2019 #4 DJ Roy said: No. Still using a number last recharged on January. Also using ₹251 plan which is just data only plan. Recieving incoming calls on both numbers. Click to expand... You are still on a plan. I've just recharged for 48 in Airtel which is a data plan and incoming/outgoing works.
iDJ Elite Contributor Joined 23 Aug 2018 Messages 24,590 Solutions 5 Reaction score 30,406 11 Sep 2019 #5 thisisjagan said: You are still on a plan. I've just recharged for 48 in Airtel which is a data plan and incoming/outgoing works. Click to expand... I have also recharged for the same on Airtel. It works. Best part is data can be rolled over to next month. OP is about Jio not Airtel.
T thisisjagan Member Joined 28 Jun 2016 Messages 1,545 Reaction score 1,797 11 Sep 2019 #6 DJ Roy said: I have also recharged for the same on Airtel. It works. Best part is data can be rolled over to next month. OP is about Jio not Airtel. Click to expand... No bro, I'm just saying as long as you are on a plan, ic/og should work. The exception should be for Jio. But you are on a plan in Jio too.
G Guri Member Joined 17 Jan 2019 Messages 122 Reaction score 42 12 Sep 2019 #7 DJ Roy said: No. Still using a number last recharged on January. Also using ₹251 plan which is just data only plan. Recieving incoming calls on both numbers. Click to expand... You are on plan, but incoming/outgoing stop only for whose plan validity expired
iDJ Elite Contributor Joined 23 Aug 2018 Messages 24,590 Solutions 5 Reaction score 30,406 12 Sep 2019 #8 Guri said: You are on plan, but incoming/outgoing stop only for whose plan validity expired Click to expand... I have another sim card. I haven't recharged for it since January.
G Guri Member Joined 17 Jan 2019 Messages 122 Reaction score 42 12 Sep 2019 #9 S DJ Roy said: I have another sim card. I haven't recharged for it since January. Click to expand... still your incoming/outgoing working
iDJ Elite Contributor Joined 23 Aug 2018 Messages 24,590 Solutions 5 Reaction score 30,406 12 Sep 2019 #10 Guri said: still your incoming/outgoing working Click to expand... Yes. Look I wanted to buy a new Tata Sky connection. I need a RMN. So am using that number since yesterday. Recieve several calls yesterday.
