iBall Slide 6351-Q40 7-inch WiFi tablet running Android 4.4 launched for Rs. 4299
Thakur
Banned
30 Aug 2013
iBall has launched iBall Slide 6351-Q40 , the latest budget tablet in the iBall Slide series.
It is an entry-level Wi-Fi Tablet, says iBall, but the earpiece on the top is weird, even though the tablet doesn’t have voice calling capabilities.
It has a 7-inch WVGA screen, powered by a 1.3GHz quad-core
processor and runs on Android 4.4 (KitKat). It has a 2- megapixel rear camera with LED flash and a VGA front- facing camera.
It has 512MB RAM, 8GB of internal storage with expansion slot and packs a 2500mAh battery.
Commenting on the launch, Sandeep Parasrampuria,
Director, iBall, said,
iBall Slide 6351-Q40 specifications
7-inch (800 x 480 pixels) capacitive multi-touch IPS display
1.3 GHz quad-core Cortex A7 processor Android 4.4 (KitKat) OS
2MP rear camera with LED flash
0.3MP (VGA) front-facing camera
3.5mm audio jack, Wireless FM Radio with Antenna
3G (via USB dongle),
WiFi 802.11 b/g/n, Bluetooth, USB OTG
512MB RAM, 8GB internal memory, 32GB expandable memory with microSD
2500 mAh battery
The iBall Slide 6351-Q40 is priced at Rs 4,299 (MRP of Rs.
4,999).
http://www.fonearena.com/blog/122260/iball-slide-6351-q40-7-inch-wifi-tablet-running-android-4-4-launched-for-rs-4299.html
