Seeking Help Help needed in Pc Build under 25K
Optimus_Prime
5 Oct 2015
My friend wanna build a PC for casual use.
Please suggest components
I've suggested following :
1.
AMD Ryzen 3 2200G with Radeon Vega 8 Graphics Desktop Processor 4 Cores up to 3.7GHz 6MB Cache AM4 Socket (YD2200C5FBBOX) https://www.amazon.in/dp/B079D3DBNM/?tag=dreamdth-21
2.GIGABYTE GA-A320M-S2H AMD A320 AM4 MAX-32GB DDR4 Micro ATX PCIE16 https://www.amazon.in/dp/B079NYQQJJ/?tag=dreamdth-21
3.Corsair Vengeance LPX 4GB (1 x 4GB) DDR4 DRAM 2400MHz (PC4-19200) C16 Memory Kit, Black https://www.amazon.in/dp/B01ARGXM0Q/?tag=dreamdth-21
4.Western Digital WD Green 480 GB 2.5 inch SATA III Internal Solid State Drive (WDS480G2G0A) https://www.amazon.in/dp/B01M3POPK3/?tag=dreamdth-21
5.Frontech 450 watt Power Supply Model JIL-2414i (SMPS with 20+4 pin) https://www.amazon.in/dp/B009CVTPZE/?tag=dreamdth-21
If you have any suggestion please feel free to suggest.
Use a better power supply, motherboard has 8 pin 12v cpu supply while psu has 4 pin, you may have to use converter
At least 8 GB ram is recommended.
Don't buy Frontech, Zebronics, Intex or Enter PSU. Buy corsair or at least 80 Plus or Bronze certified PSU. Cheap PSU may cause issues and your PC components will always be at risk.
Buy WD blue.
