CPU-Z for Android updated, now shows battery capacity, Adreno GPU clock speed & more
CPU-Z was released for Android back in June last year. Since then the app has been updated with new features and support for SoCs from several manufacturers. Few months back the app got improved support for Intel SoCs, option to view OpenGL ES version. Now the app has been updated to version 1.09 that brings improved support for processors based on big.LITTLE technology, adds new HiSilicon Kirin 920, Exynos 5433, Snapdragon 815 and SoCs, shows Adreno GPU clock speed and more.
Previously is was showing battery technology, health, temperature and voltage, now it also shows the total battery capacity in mAh. It also shows screen size in inches, in addition to the screen resolution.
Check out the complete changelog below.
Improved support of big.LITTLE technology
Screen size (in inches)
Battery capacity (in mAh)
Added new SoCs : HiSilicon Kirin 920, Exynos 5433, Snapdragon 815 …
New icon
Download CPU-Z for Android (2.0 or later) from the Google Play Store for free, if you don’t have it yet.
CPU-Z for Android updated, now shows battery capacity, Adreno GPU clock speed and more
Good application to check Hardware on PC & Now for Android phones,Thanks for sharing bro.
