Dear friends,
I have a SOLID HDS2-2100 set-top box which is powered by batteries/solar cells. So now I wanted a compact tv which would work atleast 3 hours on battery and side by side could be used as a CCTV monitor as well as instant source of entertainment by digital cable/DTH.
I got this 9 inch rechargeable LCD TV with Analog TV/DVD/USB/SD Card/FM, Solar Ready and it works on a 9 Volts DC adapter (charger) with built-in 3000mAh Lithium-ion battery used in tablet pc. The LCD panel is high-grade, IPS and electronic components are of good quality. The dealer gave me one-year warranty and servicing is done there itself by trained representative. Price is Rs2350 inclusive of all taxes for walk-in shop purchase in South Mumbai.
When taken outdoors, DD National (VHF 230MHz-237MHz) and DD News (180MHz-187MHz) can be received by whip antenna provided in the package. For better reception of terrestrial channels, one can use a one meter long telescopic antenna.
Timings:
Full recharge time = 2 hours with 9 Volts, 1.5 Amps adapter.
Watching DVD/CD/USB on battery = approx 3 hours.
Watching only TV/DTH on batt = approx 3.5 hours.
Screen Resolution: WVGA (800 X 480 pixels), Aspect Ratio: 16:9
TV Tuner: PAL, NTSC, SECAM
Power Input: 9 Volts, 1.5 Amperes
Power Consumption: 13 Watts
Some more pics:
Timings:
Some more pics:
